C6 LS3 und LS7 SLP Blackwing Cold Air Intake
Beitragvon Sonopanic » 21.11.19, 23:40
Ich habe das Teil 2018 aus USA bestellt, bin aber nicht zum Einbau gekommen. Ist also unbenutzt.
Vielleicht will ja jemand übern Winter was basteln.
Wobei der Einbau sicher in ner Stunde erledigt ist.
Ich möchte 330 € dafür.
Versand inclusive.
Von SLP kopiert :
SLP Performance 21121 - SLP LS3 C6 LS7 ZO6 and GS Blackwing Cold-Air Induction System; 2006-2013.
One of the quickest and best ways to improve the performance of your C6 LS3 or ZO6 LS7 Corvette is to eliminate the stock air box. This easy-to-install air filter package from SLP (called the Blackwing for its unique appearance) out-flows the factory setup by as much as 90% and can provide up to +10 additional horsepower and +11 ft/lbs at the flywheel. The Blackwing uses a wire-reinforced, reusable and washable blue high-flow filter media that requires re-oiling (#25017 cleaning/oil kit) after cleaning for maximum filtration. The Blackwing also features an exclusive built-in flow indicator that changes color when cleaning is required. Also included in the package is a factory style finished high-volume air bridge with integrated MAF housing and secure mounting points. This is a simple bolt-on installation that requires no cutting or vehicle modifications.
Corvette C6 - 2008, 2009, 2010, 2011, 2012, 2013
Corvette Grand Sport - 2010, 2011, 2012, 2013
Corvette ZO6 - 2006, 2007, 2008, 2009, 2010, 2011, 2012, 2013
Sonopanic
Fahrzeug: C6, 2007, schwarz
