Liste Fehlercodes
5 Beiträge
Liste Fehlercodes
Hi Zusammen
Gibts wo eine Liste wo gezeigt wird was Die Fehlercodes zu sagen haben
Bei mir in der C6 waren so viele ....puhh !!
vg und Danke
vg und Danke
- AAron
- Bilder: 4
Re: Liste Fehlercodes
...hast PN!
CU
CU
rssc - Beiträge: 310
- Bilder: 11
- Fahrzeug: C6 GS, Torch Red
Warum so geheimnisvoll mit PM? ist doch von allgemeinem Interesse. Wenn schon ein Moderator das reinstellen anbietet, dann hier aber leider Englisch:
Quelle: http://www.digitalcorvettes.com/forums/ ... hp?t=50987
This master DTC list includes all applicable DTCs in alphanumeric order with descriptors.
DTC
DTC Descriptor
Module That Sets the DTC
Diagnostic Procedure section in Service Manual.
B0001
Vehicle Speed Information Circuit Range/Performance
Navigation Radio
DTC B0001 in Navigation Systems
B0005
In Park Switch Circuit
BCM, SCLCM
DTC B0005 in Steering Wheel and Column
B0012
Passenger Frontal Deployment Loop Stage 2 Resistance Low
SDM
DTC B0012, B0013, B0014, B0016, B0017, or B0018 in SIR
B0013
Passenger Frontal Deployment Loop Stage 2 Open
SDM
B0014
Passenger Frontal Deployment Loop Stage 2 Voltage Out of Range
SDM
B0016
Passenger Frontal Deployment Loop Stage 1 Resistance Low
SDM
B0017
Passenger Frontal Deployment Loop Stage 1 Open
SDM
B0018
Passenger Frontal Deployment Loop Stage 1 Voltage Out of Range
SDM
B0022
Driver Frontal Deployment Loop Stage 1 Resistance Low
SDM
DTC B0022, B0024, B0026, B0042, B0043, or B0044 in SIR
B0024
Driver Frontal Deployment Loop Stage 1 Voltage Out of Range
SDM
B0026
Driver Frontal Deployment Loop Stage 1 Open
SDM
B0028
Right Front Side Deployment Loop Resistance Low
SDM
DTC B0028, B0029, or B0030 in SIR
B0029
Right Front Side Deployment Loop Open
SDM
B0030
Right Front Side Deployment Loop Voltage Out of Range
SDM
B0040
Left Front Side Deployment Loop Resistance Low
SDM
DTC B0040, B0041, or B0045 in SIR
B0041
Left Front Side Deployment Loop Open
SDM
B0042
Driver Frontal Deployment Loop Stage 2 Resistance Low
SDM
B0043
Driver Frontal Deployment Loop Stage 2 Voltage Out of Range
SDM
B0044
Driver Frontal Deployment Loop Stage 2 Open
SDM
B0045
Left Front Side Deployment Loop Voltage Out of Range
SDM
B0051
Deployment Commanded
SDM
DTC B0051 in SIR
B0053
Deployment Commanded with Loop DTCs Present
SDM
DTC B0053 in SIR
B0057
Right Front Pretensioner Deployment Loop Resistance Low
SDM
DTC B0057, B0058, or B0059 in SIR
B0058
Right Front Pretensioner Deployment Loop Open
SDM
B0059
Right Front Pretensioner Deployment Loop Voltage Out of Range
SDM
B0064
Left Front Pretensioner Deployment Loop Resistance Low
SDM
DTC B0064, B0065, or B0066 in SIR
B0065
Left Front Pretensioner Deployment Loop Open
SDM
B0066
Left Front Pretensioner Deployment Loop Voltage Out of Range
SDM
B0077
Driver Side Impact Sensor (SIS) Performance
SDM
DTC B0077, B0078, B0079, B0080, B0081, or B0082 in SIR
B0078
Passenger Side Impact Sensor (SIS) Performance
SDM
B0079
Incorrect Driver Side Impact Sensor (SIS) Installed
SDM
B0080
Discard Driver Side Impact Sensor (SIS)
SDM
B0081
Incorrect Passenger Side Impact Sensor (SIS) Installed
SDM
B0082
Discard Passenger Side Impact Sensor (SIS)
SDM
B0083
Right Front Seat Position Sensor Circuit
SDM
DTC B0083 or B0084 in SIR
B0084
Left Front Seat Position Sensor Circuit
SDM
B0090
Active Switch Voltage Out of Range
SDM
DTC B0090 in SIR
B0091
Active Switch: Wrong State
SDM
DTC B0091 in SIR
B0100
Front End Sensor 1 Performance
SDM
DTC B0100, B0101, B0102, B0103, B0104, or B0105 in SIR
B0101
Discard Front End Sensor 1
SDM
B0102
Incorrect Front End Sensor 1 Installed
SDM
B0103
Front End Sensor 2 Performance
SDM
B0104
Discard Front End Sensor 2
SDM
B0105
Incorrect Front End Sensor 2 Installed
SDM
B0159
Outside Air Temperature Sensor Circuit
HVAC
DTC B0159 or B0164 in HVAC Systems - Automatic
B0164
Passenger Compartment Temperature Sensor Circuit
HVAC
B0174
Output Air Temperature Sensor 1
HVAC
DTC B0174, B0179, B0510, or B0515 in HVAC Systems - Automatic
B0179
Output Air Temperature Sensor 2
HVAC
B0184
Solar Load Sensor 1 Circuit Performance
HVAC
DTC B0184 or B0189 in HVAC Systems - Automatic
B0189
Solar Load Sensor 2 Circuit Performance
HVAC
B0248
Air Flow Control 3 Circuit
HVAC
DTC B0248, B0268, B0408, or B0423 in HVAC Systems - Automatic
B0249
Air Flow Control 3 Circuit Range
HVAC
DTC B0249, B0269, B0409, or B0419 in HVAC Systems - Automatic
B0268
Air Flow Control 7 Circuit
HVAC
B0269
Air Flow Control 7 and Circuit Range
HVAC
B0408
Temperature Control 1 Circuit
HVAC
B0409
Temperature Control 1 Circuit Range
HVAC
B0419
Temperature Control 2 Circuit Range
HVAC
B0423
HVAC
B0510
Output Air Temperature Sensor 3
HVAC
B0515
Output Air Temperature Sensor 4
HVAC
B0976
Power Mode OFF Indicator Circuit
BCM
DTC B0976, B0977, or B0978 in Computer/Integrating Systems
B0977
Power Mode START Indicator Circuit
BCM
B0978
Power Mode ACCESSORY Indicator Circuit
BCM
B1000
Electronic Control Unit (ECU) Performance
DSCC, BCM, DDM, DRR, RCDLR, FTC, HUD, HVAC, IPC, PDM, Radio, SCLCM, SDM, VCIM
DTC B1000 in Computer/Integrating Systems
B1001
Option Configuration Error
BCM
DTC B1001 in Computer/Integrating Systems
DRR, Radio,
DTC B1001 in Entertainment
SDM
DTC B1001 in SIR
B1004
Keep Alive Memory (KAM) Reset
Audio Amplifier, DDS, HVAC, SCLCM, VCIM
DTC B1004 in Computer/Integrating Systems
B1007
EEPROM Write Error
Audio Amplifier, DDS, DPM, FTC, SCLCM
DTC B1007 in Computer/Integrating Systems
B1009
EEPROM Checksum Mismatch
Audio Amplifier, DDS, DPM, FTC, SCLCM, VCIM
DTC B1009 in Computer/Integrating Systems
B1011
System Disabled Information Stored
DDM, PDM
DTC B1011 in Doors
FTC
DTC B1011 in Roof
B1013
Calibration Read Only Memory (ROM) Checksum Error
HVAC
DTC B1013 in Computer/Integrating Systems
B1014
Program Read Only Memory (ROM) Checksum Error
HVAC
DTC B1014 in Computer/Integrating Systems
B1259
Antenna Ground Circuit
Radio
DTC B1259 in Entertainment
B1271
Theft Locked
Radio
DTC B1271 in Entertainment
B1291
Convertible Top Fifth Bow Position
FTC
DTC B1291 in Roof
B1325
Device Power 1 Circuit Voltage
BCM
DTC B1325 in Engine Electrical
B1327
Device Power 1 Circuit Low
Audio Amplifier, DRR, DPM, FTC, HVAC, SDM, SCLCM, VCIM, DDS
DTC B1327 in Engine Electrical
B1328
Device Power 1 Circuit High
Audio Amplifier, FTC, HVAC, SCLCM, SDM
DTC B1328 in Engine Electrical
B1336
Device Power 3 Circuit Range/Performance
DPM/MSM
DTC B1336 in Seats
B1370
Device Ignition 1 (ON and START) Circuit
RCDLR
DTC B1370 in Computer/Integrating Systems
B1420
Device Voltage
DDM, PDM
DTC B1420 in Doors
FTC
DTC B1420 in Roof
DPM/MSM
DTC B1420 in Seats
B1440
Power Mode Master Input Circuits Mismatch
RCDLR
DTC B1440 in Computer/Integrating Systems
B1451
Accessory Power Circuit
BCM
DTC B1451 in Computer/Integrating Systems
B1474
Right Front Exterior Door Handle Switch Circuit
DDM, PDM, RCDLR
DTC B1474, B2981, B3848, or B3849 in Doors
B1480
Battery Rundown Protection Circuit
BCM
DTC B1480 in Lighting Systems
B1580
Left Front Mirror Horizontal Position Sensor Circuit
DDM, PDM
DTC B1580 or B1590 in Doors
B1590
Left Front Mirror Vertical Position Sensor Circuit
DDM, PDM
B1600
Mirror Motor 1 (vertical) Circuit
DDM, PDM
DTC B1600 or B1605 in Doors
B1605
Mirror Motor 2 (horizontal) Circuit
DDM, PDM
B1697
Mirror Left-Up Control Switch Circuit Low
DDSA
DTC B1697, B1702, B1707, or B1712 in Doors
B1702
Mirror Left-Down Control Switch Circuit Low
DDSA
B1707
Mirror Right-Up Control Switch Circuit Low
DDSA
B1712
Mirror Right-Down Control Switch Circuit Low
DDSA
B1735
Seat Front Up Switch Circuit
DPM/MSM
DTC B1735, B1740, B1745, B1750, B1755, B1760, B1815, or B1820 in Seats
B1740
Seat Front Down Switch Circuit
DPM/MSM
B1745
Seat Rear Up Switch Circuit
DPM/MSM
B1750
Seat Rear Down Switch Circuit
DPM/MSM
B1755
Seat Assembly Horizontal Forward Switch Circuit
DPM/MSM
B1760
Seat Assembly Horizontal Rearward Switch Circuit
DPM/MSM
B1815
Seat Recline Forward Switch Circuit
DPM/MSM
B1820
Seat Recline Rearward Switch Circuit
DPM/MSM
B1825
Seat Recline Position Sensor Circuit
DPM/MSM
DTC B1825, B1850, B2355, B2365, or B2375 in Seats
B1826
Seat Recline Position Sensor Circuit Range/Performance
DPM/MSM
DTC B1826, B1851, B1861, B2356, B2366, or B2376 in Seats
B2355
Seat Front Vertical Position Sensor Circuit
DPM/MSM
B2356
Seat Front Vertical Position Sensor Circuit Range/Performance
DPM/MSM
B2365
Seat Rear Vertical Position Sensor Circuit
DPM/MSM
B2366
Seat Rear Vertical Position Sensor Circuit Range/Performance
DPM/MSM
B2375
Seat Assembly Horizontal Position Sensor Circuit
DPM/MSM
B2376
Seat Assembly Horizontal Position Sensor Circuit Range/Performance
DPM/MSM
B2455
Cellular Phone Microphone Circuit
VCIM
DTC B2455 in Cellular Communication
B2462
Global Positioning System (GPS) Signal Error
Navigation Radio
DTC B2462 in Navigation Systems
B2470
Cellular Phone Antenna Circuit
VCIM
DTC B2470 in Cellular Communication
B2476
Cellular Phone Select Service Switch
VCIM
DTC B2476 in Cellular Communication
B2482
Cellular Phone Select Service Switch Performance
VCIM
DTC B2482 in Cellular Communication
B2483
Global Positioning System (GPS) Sensor Circuit Low
VCIM
DTC B2483 or B2484 in Cellular Communication
B2484
Global Positioning System (GPS) Sensor Circuit Open
VCIM
B2510
Steering Column Lock Motor Unlock Circuit
SCLCM
DTC B2510 in Steering Wheel and Column
B2515
Steering Column Lock Motor Feedback Circuit
SCLCM
DTC B2515 in Steering Wheel and Column
B2517
Left Front Door Latch Circuit
DDM, PDM
DTC B2517 or B2518 in Doors
B2518
Right Front Door Latch Circuit
DDM, PDM
B2527
Front Fog Lamps Circuit Low
BCM
DTC B2527 in Horns
B2528
Front Foglamps Circuit High
BCM
DTC B2528 in Horns
B2530
Front Foglamps Control Circuit
BCM
DTC B2530 in Lighting Systems
B2540
Rear Foglamps Control Circuit
BCM
DTC B2540 in Lighting Systems
B2567
Under hood Lamp Control Circuit Low
BCM
DTC B2567 in Body Rear End
B2573
Trunk/Hatch Lamp Control Circuit High
BCM
DTC B2573 in Body Rear End
B2580
Headlamp High Beam Control Circuit
BCM
DTC B2580 in Lighting Systems
B2625
Display Dimming Pulse Width Modulation (PWM) Output Circuit
BCM
DTC B2625 in Computer/Integrating Systems
B2710
Gearshift Lock Circuit
RCDLR
DTC B2710 in Shift Lock Control
B2757
Memory 1 Select Switch Circuit Low
DDM
DTC B2757, B2762, B2767, or B2772 in Seats
B2762
Memory 2 Select Switch Circuit Low
DDM
B2853
Telescope Forward Switch Circuit High
DPM/MSM
DTC B2853, B2858, B2873, or B2878 in Steering Wheel and Column
B2858
Telescope Rearward Switch Circuit High
DPM/MSM
B2860
Telescope Position Sensor
DPM/MSM
DTC B2860 in Steering Wheel and Column
B2873
Tilt Up Switch Circuit High
DPM/MSM
B2878
Tilt Down Switch Circuit High
DPM/MSM
B2897
Steering Column Lock Motor Lock Circuit
SCLCM
DTC B2897 in Steering Wheel and Column
B2907
Steering Column Lock Motor Enable Relay Circuit
BCM, SCLCM
DTC B2907 in Steering Wheel and Column
B2910
Steering Column Lock Password Incorrect
SCLCM
DTC B2910 in Steering Wheel and Column
B2981
Right Front Door Handle Switch Circuit
DDM, PDM, RCDLR
B3089
Content Theft System Intrusion Sensor Signal Circuit
BCM
DTC B3089 in Theft Deterrent
B3119
Keyless Entry Antenna 1 Performance
RCDLR
DTC B3119 in Keyless Entry
B3120
Keyless Entry Antenna 2 Performance
RCDLR
DTC B3120 in Keyless Entry
B3121
Keyless Entry Antenna 3 Performance
RCDLR
DTC B3121 in Keyless Entry
B3122
Keyless Entry Antenna 4 Performance
RCDLR
DTC B3122 in Keyless Entry
B3142
Left Front Unlock Switch Circuit Low
DDSA
DTC B3142 or B3152 in Doors
B3145
Right Front Unlock Switch Circuit Low
PDM
DTC B3145 or B3155 in Doors
B3152
Left Front Lock Switch Circuit Low
DDSA
B3155
Right Front Lock Switch Circuit Low
PDM
B3170
Right Front Window Up Switch Circuit
PDM
DTC B3170, B3175, or B3280 in Doors
B3175
Right Front Window Down Switch Circuit
PDM
B3205
Left Front Window Motor Circuit
DDM
DTC B3205 in Doors
B3280
Right Front Window Express Up or Down Circuit
PDM
B3377
Left Front Window Up Switch Circuit Low
DDSA
DTC B3377, B3382, B3387, B3392, B3467, or B3472 in Doors
B3382
Left Front Window Down Switch Circuit Low
DDSA
B3387
Right Front Window Up Switch Circuit Low
DDSA
B3392
Right Front Window Down Switch Circuit Low
DDSA
B3467
Left Front Window Express Up or Down Circuit Low
DDSA
B3472
Right Front Window Express Up or Down Circuit Low
DDSA
B3542
Left Front Window Obstruction Sensor Control Circuit
DDM, PDM
DTC B3542 in Doors
B3602
Convertible Top Control Switch
FTC
DTC B3602 in Roof
B3618
Exterior Trunk Release Switch Circuit Low
BCM
DTC B3618 in Body Rear End
B3619
Head-Up Display (HUD) Change Page Switch Circuit
HUD
DTC B3619 in Instrument Panel, Gages, and Console
B3620
Head Up Display (HUD) Information Up Switch Circuit
HUD
DTC B3620 in Instrument Panel, Gages, and Console
B3621
Head Up Display (HUD) Information Down Switch Circuit
HUD
DTC B3621 in Instrument Panel, Gages, and Console
B3634
Head Up Display (HUD) Dimming (Up) Switch Circuit
HUD
DTC B3634 in Instrument Panel, Gages, and Console
B3659
Head Up Display (HUD) Dimming Down Switch Circuit
HUD
DTC B3659 in Instrument Panel, Gages, and Console
B3666
Rear Tonneau Position Error
FTC
DTC B3666 in Roof
B3667
Tonneau Release Circuit
FTC
DTC B3667 in Roof
B3670
Pump Motor Temperature Sensor Circuit
FTC
DTC B3670 in Roof
B3715
Front Wiper Relay Drive Circuit
BCM
DTC B3715 in Wipers/Washer Systems
B3744
Head Up Display (HUD) Mode Switch Circuit
HUD
DTC B3744 in Instrument Panel, Gages, and Console
B3794
Cruise Control Function Request Circuit
BCM
DTC B3794 in Cruise Control
B3810
Headlamp Washer Relay Circuit
BCM
DTC B3810 in Wipers/Washer Systems
B3848
Interior Door Handle Switch Circuit
DDM, PDM, RCDLR
B3849
Left Front Exterior Door Handle Switch Circuit
DDM, PDM, RCDLR
B3948
Left Front Turn Signal Circuit
BCM
DTC B3948 in Lighting Systems
B3949
Right Front Turn Signal Circuit
BCM
DTC B3949 in Lighting Systems
B3950
Left Rear Turn Signal Circuit
BCM
DTC B3950 in Lighting Systems
B3951
Right Rear Turn Signal Circuit
BCM
DTC B3951 in Lighting Systems
B3971
Folding Top Position Sensor
FTC
DTC B3971 in Roof
C0035
Left Front Wheel Speed Sensor Circuit
EBCM
DTC C0035-C0050 in Antilock Brake System
C0040
Right Front Wheel Speed Sensor Circuit
EBCM
C0045
Left Rear Wheel Speed Sensor Circuit
EBCM
C0050
Right Rear Wheel Speed Sensor Circuit
EBCM
C0110
Pump Motor Circuit
EBCM
DTC C0110 in Antilock Brake System
C0136
Base Brake System Pressure Circuit
EBCM
DTC C0136 in Antilock Brake System
C0137
Base Brake System Pressure Circuit Range
EBCM
DTC C0137 in Antilock Brake System
C0161
Antilock Brake System (ABS)/Traction Control System (TCS) Brake Switch Circuit
EBCM
DTC C0161 in Antilock Brake System
C0179
System Thermal High
EBCM
DTC C0179 in Antilock Brake System
C0186
Lateral Accelerometer Circuit
EBCM
DTC C0186 in Antilock Brake System
C0196
Yaw Rate Circuit
EBCM
DTC C0196 in Antilock Brake System
C0220
Left Front Antilock Brake System (ABS) Channel in Release Too Long
EBCM
DTC C0220-C0229 in Antilock Brake System
C0221
Right Front Antilock Brake System (ABS) Channel in Release Too Long
EBCM
C0228
Left Rear Antilock Brake System (ABS) Channel in Release Too Long
EBCM
C0229
Right Rear Antilock Brake System (ABS) Channel in Release Too Long
EBCM
C0240
Powertrain Control Module (PCM) Traction Control Not Allowed
EBCM
DTC C0240 in Antilock Brake System
C0242
Powertrain Control Module (PCM) Indicated TCS Malfunction
EBCM
DTC C0242 in Antilock Brake System
C0249
Left Normal Force Error
EBCM
DTC C0249 or C0250 in Antilock Brake System
C0250
Right Normal Force Error
EBCM
C0252
Vehicle Stability Enhancement System (VSES) Sensors Uncorrelated
EBCM
DTC C0252 in Antilock Brake System
C0253
Centering Error
EBCM
DTC C0253 in Antilock Brake System
C0267
Low Brake Fluid Indicated
EBCM
DTC C0267 in Hydraulic Brakes
C0277
Brake Pedal Position Sensor Circuit
BCM
DTC C0277 in Lighting Systems
C0278
Brake Pedal Position Sensor Not Calibrated
BCM
DTC C0278 in Lighting Systems
C0281
Dynamic Rear Proportioning (DRP) Performance
EBCM
DTC C0281 in Antilock Brake System
C0550
EBCM
DTC C0550 in Antilock Brake System
ESC
DTC C0550 in Electronic Suspension Control (ESC)
C0551
EBCM
DTC C0551 in Antilock Brake System
C0558
Calibration Data Not Programmed
ESC
DTC C0558 in Electronic Suspension Control (ESC)
C0561
EBCM
DTC C0561 in Antilock Brake System
C0565
Vehicle Identification Number (VIN) Information Error
EBCM
DTC C0565 in Antilock Brake System
C0575
Left Front Solenoid/Motor/Actuator Circuit
ESC
DTC C0575, C0580, C0585, or C0590 in Electronic Suspension Control (ESC)
C0580
Right Front Solenoid/Motor/Actuator Circuit
ESC
C0585
Left Rear Solenoid/Motor/Actuator Circuit
ESC
C0590
Right Rear Solenoid/Motor/Actuator Circuit
ESC
C0615
Left Front Position Sensor Circuit
ESC
DTC C0615, C0620, C0625 or C0630 in Electronic Suspension Control (ESC)
C0620
Right Front Position Sensor Circuit
ESC
C0625
Left Rear Position Sensor Circuit
ESC
C0630
Right Rear Position Sensor Circuit
ESC
C0696
Position Sensor Overcurrent (5-volt supply)
ESC
DTC C0696 in Electronic Suspension Control (ESC)
C0710
Steering Position Signal
RCDLR
DTC C0710 in Antilock Brake System
C0750
Left Front Low Tire Pressure Sensor
RCDLR
DTC C0750, C0755, C0760, or C0765 in Tire Pressure Monitoring
C0755
Right Front Low Tire Pressure Sensor
RCDLR
C0760
Left Rear Low Tire Pressure Sensor
RCDLR
C0765
Right Rear Low Tire Pressure Sensor
RCDLR
C0820
EBCM Case Voltage
EBCM
DTC C0820 in Antilock Brake System
C0870
Device Voltage Reference Output 1 Circuit
EBCM
DTC C0870 in Antilock Brake System
BCM
DTC C0870 in Lighting Systems
C0895
Device Voltage
ESC
DTC C0895 in Electronic Suspension Control (ESC)
C0899
Device 1 Voltage Low
EBCM
DTC C0899 in Antilock Brake System
C0900
Device 1 Voltage High
EBCM
DTC C0900 in Antilock Brake System
C1241
Steering Assist Control Actuator Circuit
EBCM
DTC C1241 in Variable Effort Steering
P0016
Crankshaft Position (CKP)-Camshaft Position (CMP) Correlation
ECM
DTC P0016 in Engine Controls - 6.0L
P0030
HO2S Heater Control Circuit Bank 1 Sensor 1
ECM
DTC P0030, P0036, P0050, or P0056 in Engine Controls - 6.0L
P0036
HO2S Heater Control Circuit Bank 1 Sensor 2
ECM
P0050
HO2S Heater Control Circuit Bank 2 Sensor 1
ECM
P0056
HO2S Heater Control Circuit Bank 2 Sensor 2
ECM
P0068
Throttle Body Airflow Performance
ECM
DTC P0068 in Engine Controls - 6.0L
P0101
Mass Air Flow (MAF) Sensor Performance
ECM
DTC P0101 in Engine Controls - 6.0L
P0102
Mass Air Flow (MAF) Sensor Circuit Low Frequency
ECM
DTC P0102 in Engine Controls - 6.0L
P0103
Mass Air Flow (MAF) Sensor Circuit High Frequency
ECM
DTC P0103 in Engine Controls - 6.0L
P0106
Manifold Absolute Pressure (MAP) Sensor Performance
ECM
DTC P0106 in Engine Controls - 6.0L
P0107
Manifold Absolute Pressure (MAP) Sensor Circuit Low Voltage
ECM
DTC P0107 in Engine Controls - 6.0L
P0108
Manifold Absolute Pressure (MAP) Sensor Circuit High Voltage
ECM
DTC P0108 in Engine Controls - 6.0L
P0112
Intake Air Temperature (IAT) Sensor Circuit Low Voltage
ECM
DTC P0112 in Engine Controls - 6.0L
P0113
Intake Air Temperature (IAT) Sensor Circuit High Voltage
ECM
DTC P0113 in Engine Controls - 6.0L
P0116
Engine Coolant Temperature (ECT) Sensor Performance
ECM
DTC P0116 in Engine Controls - 6.0L
P0117
Engine Coolant Temperature (ECT) Sensor Circuit Low Voltage
ECM
DTC P0117 in Engine Controls - 6.0L
P0118
Engine Coolant Temperature (ECT) Sensor Circuit High Voltage
ECM
DTC P0118 in Engine Controls - 6.0L
P0120
Throttle Position (TP) Sensor 1 Circuit
ECM
DTC P0120 in Engine Controls - 6.0L
P0121
Throttle Position (TP) Sensor 1 Performance
ECM
DTC P0121 in Engine Controls - 6.0L
P0122
Throttle Position (TP) Sensor 1 Circuit Low Voltage
ECM
DTC P0122 in Engine Controls - 6.0L
P0123
Throttle Position (TP) Sensor 1 Circuit High Voltage
ECM
DTC P0123 in Engine Controls - 6.0L
P0128
Engine Coolant Temperature (ECT) Below Thermostat Regulating Temperature
ECM
DTC P0128 in Engine Controls - 6.0L
P0131
HO2S Circuit Low Voltage Bank 1 Sensor 1
ECM
DTC P0131 or P0151 in Engine Controls - 6.0L
P0132
HO2S Circuit High Voltage Bank 1 Sensor 1
ECM
DTC P0132 or P0152 in Engine Controls - 6.0L
P0133
HO2S Slow Response Bank 1 Sensor 1
ECM
DTC P0133 or P0153 in Engine Controls - 6.0L
P0134
HO2S Circuit Insufficient Activity Bank 1 Sensor 1
ECM
DTC P0134 or P0154 in Engine Controls - 6.0L
P0135
HO2S Heater Performance Bank 1 Sensor 1
ECM
DTC P0135, P0141, P0155, or P0161 in Engine Controls - 6.0L
P0136
HO2S Circuit Bank 1 Sensor 2
ECM
DTC P0136 or P0156 in Engine Controls - 6.0L
P0137
HO2S Circuit Low Voltage Bank 1 Sensor 2
ECM
DTC P0137 or P0157 in Engine Controls - 6.0L
P0138
HO2S Circuit High Voltage Bank 1 Sensor 2
ECM
DTC P0138 or P0158 in Engine Controls - 6.0L
P0140
HO2S Circuit Insufficient Activity Bank 1 Sensor 2
ECM
DTC P0140 or P0160 in Engine Controls - 6.0L
P0141
HO2S Heater Performance Bank 1 Sensor 2
ECM
P0151
HO2S Circuit Low Voltage Bank 2 Sensor 1
ECM
P0152
HO2S Circuit High Voltage Bank 2 Sensor 1
ECM
P0153
HO2S Slow Response Bank 2 Sensor 1
ECM
P0154
HO2S Circuit Insufficient Activity Bank 2 Sensor 1
ECM
P0155
HO2S Heater Performance Bank 2 Sensor 1
ECM
P0156
HO2S Circuit Bank 2 Sensor 2
ECM
P0157
HO2S Circuit Low Voltage Bank 2 Sensor 2
ECM
P0158
HO2S Circuit High Voltage Bank 2 Sensor 2
ECM
P0160
HO2S Circuit Insufficient Activity Bank 2 Sensor 2
ECM
P0161
HO2S Heater Performance Bank 2 Sensor 2
ECM
P0171
Fuel Trim System Lean Bank 1
ECM
DTC P0171 or P0174 in Engine Controls - 6.0L
P0172
Fuel Trim System Rich Bank 1
ECM
DTC P0172 or P0175 in Engine Controls - 6.0L
P0174
Fuel Trim System Lean Bank 2
ECM
P0175
Fuel Trim System Rich Bank 2
ECM
P0201
Injector 1 Control Circuit
ECM
DTC P0201-P0208 in Engine Controls - 6.0L
P0202
Injector 2 Control Circuit
ECM
P0203
Injector 3 Control Circuit
ECM
P0204
Injector 4 Control Circuit
ECM
P0205
Injector 5 Control Circuit
ECM
P0206
Injector 6 Control Circuit
ECM
P0207
Injector 7 Control Circuit
ECM
P0208
Injector 8 Control Circuit
ECM
P0218
Transmission Fluid Overtemperature
TCM
DTC P0218 in Automatic Transmission - 4L60-E/4L80-E
P0220
Throttle Position (TP) Sensor 2 Circuit
ECM
DTC P0220 in Engine Controls - 6.0L
P0222
Throttle Position (TP) Sensor 2 Circuit Low Voltage
ECM
DTC P0222 in Engine Controls - 6.0L
P0223
Throttle Position (TP) Sensor 2 Circuit High Voltage
ECM
DTC P0223 in Engine Controls - 6.0L
P0230
Fuel Pump Relay Control Circuit
ECM
DTC P0230 in Engine Controls - 6.0L
P0300
Engine Misfire Detected
ECM
DTC P0300 in Engine Controls - 6.0L
P0315
Crankshaft Position (CKP) System Variation Not Learned
ECM
DTC P0315 in Engine Controls - 6.0L
P0325
Knock Sensor (KS) Circuit
ECM
DTC P0325 in Engine Controls - 6.0L
P0326
Knock Sensor (KS) Performance
ECM
DTC P0326 in Engine Controls - 6.0L
P0327
Knock Sensor (KS) 1 Circuit Low Frequency
ECM
DTC P0327 or P0332 in Engine Controls - 6.0L
P0332
Knock Sensor (KS) 2 Circuit Low Frequency
ECM
P0335
Crankshaft Position (CKP) Sensor Circuit
ECM
DTC P0335 in Engine Controls - 6.0L
P0336
Crankshaft Position (CKP) Sensor Performance
ECM
DTC P0336 in Engine Controls - 6.0L
P0340
Camshaft Position (CMP) Sensor Circuit
ECM
DTC P0340 in Engine Controls - 6.0L
P0341
Camshaft Position (CMP) Sensor Performance
ECM
DTC P0341 in Engine Controls - 6.0L
P0351
Ignition Coil 1 Control Circuit
ECM
DTC P0351-P0358 in Engine Controls - 6.0L
P0352
Ignition Coil 3 Control Circuit
ECM
P0353
ECM
P0354
Ignition Coil 4 Control Circuit
ECM
P0355
Ignition Coil 5 Control Circuit
ECM
P0356
Ignition Coil 6 Control Circuit
ECM
P0357
Ignition Coil 7 Control Circuit
ECM
P0358
Ignition Coil 8 Control Circuit
ECM
P0420
Catalyst System Low Efficiency Bank 1
ECM
DTC P0420 or P0430 in Engine Controls - 6.0L
P0430
Catalyst System Low Efficiency Bank 2
ECM
P0442
Evaporative Emission (EVAP) System Small Leak Detected
ECM
DTC P0442 in Engine Controls - 6.0L
P0443
Evaporative Emission (EVAP) Purge Solenoid Control Circuit
ECM
DTC P0443 in Engine Controls - 6.0L
P0446
Evaporative Emission (EVAP) Vent System Performance
ECM
DTC P0446 in Engine Controls - 6.0L
P0449
Evaporative Emission (EVAP) Vent Solenoid Control Circuit
ECM
DTC P0449 in Engine Controls - 6.0L
P0451
Fuel Tank Pressure (FTP) Sensor Performance
ECM
DTC P0451 in Engine Controls - 6.0L
P0452
Fuel Tank Pressure (FTP) Sensor Circuit Low Voltage
ECM
DTC P0452 in Engine Controls - 6.0L
P0453
Fuel Tank Pressure (FTP) Sensor Circuit High Voltage
ECM
DTC P0453 in Engine Controls - 6.0L
P0454
Fuel Tank Pressure (FTP) Sensor Circuit Intermittent
ECM
DTC P0454 in Engine Controls - 6.0L
P0455
Evaporative Emission (EVAP) System Large Leak Detected
ECM
DTC P0455 in Engine Controls - 6.0L
P0461
Fuel Level Sensor 1 Performance
ECM
DTC P0461 in Instrument Panel, Gages, and Console
P0462
Fuel Level Sensor 1 Circuit Low Voltage
ECM
DTC P0462 in Instrument Panel, Gages, and Console
P0463
Fuel Level Sensor 1 Circuit High Voltage
ECM
DTC P0463 in Instrument Panel, Gages, and Console
P0464
Fuel Level Sensor Circuit Intermittent
ECM
DTC P0464 in Instrument Panel, Gages, and Console
P0496
Evaporative Emission (EVAP) System Flow During Non-Purge
ECM
DTC P0496 in Engine Controls - 6.0L
P0502
Vehicle Speed Sensor (VSS) Circuit Low Voltage
ECM
DTC P0502 in Manual Transmission - Tremec 6-Speed
P0503
Vehicle Speed Sensor (VSS) Circuit Intermittent
ECM
DTC P0503 in Manual Transmission - Tremec 6-Speed
P0506
Idle Speed Low
ECM
DTC P0506 in Engine Controls - 6.0L
P0507
Idle Speed High
ECM
DTC P0507 in Engine Controls - 6.0L
P0521
Engine Oil Pressure (EOP) Sensor Performance
ECM
DTC P0521 in Instrument Panel, Gages, and Console
P0522
Engine Oil Pressure (EOP) Sensor Circuit Low Voltage
ECM
DTC P0522 in Instrument Panel, Gages, and Console
P0523
Engine Oil Pressure (EOP) Sensor Circuit High Voltage
ECM
DTC P0523 in Instrument Panel, Gages, and Console
P0531
Air Conditioning (A/C) Refrigerant Pressure Sensor Performance
HVAC
DTC P0531, P0532, or P0533 in HVAC Systems - Automatic
P0532
Air Conditioning (A/C) Refrigerant Pressure Sensor Circuit Low Voltage
HVAC
P0533
Air Conditioning (A/C) Refrigerant Pressure Sensor Circuit High Voltage
HVAC
P0562
System Voltage Low
ECM
DTC P0562 in Engine Electrical
TCM
DTC P0562 in Automatic Transmission - 4L60-E/4L65-E
P0563
System Voltage High
ECM
DTC P0563 in Engine Electrical
TCM
DTC P0563 in Automatic Transmission - 4L60-E/4L65-E
P0572
Brake Switch Circuit 1 Low Voltage
ECM
DTC P0572 in Lighting Systems
P0573
Brake Switch Circuit 1 High Voltage
ECM
DTC P0573 in Lighting Systems
P0575
Cruise Control Switch Signal Circuit
ECM
DTC P0575 in Cruise Control
P0601
Control Module Read Only Memory (ROM)
ECM
DTC P0601-P0607, P060E, P1600, P1621, P1627, P1681, P1683, or P2610 in Engine Controls - 6.0L
P0601
Transmission Control Module (TCM) Read Only Memory (ROM)
TCM
DTC P0601-P0604 or P1621 in Automatic Transmission - 4L60-E/4L65-E
P0602
Control Module Not Programmed
ECM
P0602
Transmission Control Module (TCM) Not Programmed
TCM
P0603
Control Module Long Term Memory Reset
ECM
P0603
Transmission Control Module (TCM) Long Term Memory Reset
TCM
P0604
Control Module Random Access Memory (RAM)
ECM
P0604
Transmission Control Module (TCM) Random Access Memory (RAM)
TCM
P0606
Control Module Internal Performance
ECM
P0607
Control Module Performance
ECM
P0608
Vehicle Speed Output Circuit
ECM
DTC P0608 in Instrument Panel, Gages, and Console
P060E
Control Module Throttle Position (TP) System Performance
ECM
P060D
Control Module Accelerator Pedal Position (APP) System Performance
ECM
DTC P060D in Engine Controls - 5.3L
P0615
Starter Relay Control Circuit
ECM
DTC P0615 in Engine Electrical
P0621
Generator L-Terminal Circuit
ECM
DTC P0621 in Engine Electrical
P0622
Generator F-Terminal Circuit
ECM
DTC P0622 in Engine Electrical
P0641
5-Volt Reference 1 Circuit
ECM
DTC P0641 in Engine Controls - 6.0L
P0646
Air Conditioning (A/C) Clutch Relay Control Circuit Low Voltage
HVAC
DTC P0646 or P0647 in HVAC Systems - Automatic
P0647
Air Conditioning (A/C) Clutch Relay Control Circuit High Voltage
HVAC
P0650
Malfunction Indicator Lamp (MIL) Control Circuit
ECM
DTC P0650 in Engine Controls - 6.0L
P0651
5-Volt Reference 2 Circuit
ECM
DTC P0651 in Engine Controls - 6.0L
P0654
Engine Speed Output Circuit
ECM
DTC P0654 in Instrument Panel, Gages, and Console
P0685
Engine Controls Ignition Relay Control Circuit
ECM
DTC P0685 in Engine Controls - 6.0L
P0689
Engine Controls Ignition Relay Feedback Circuit Low Voltage
ECM
DTC P0689 in Engine Controls - 6.0L
P0690
Engine Controls Ignition Relay Feedback Circuit High Voltage
ECM
DTC P0690 in Engine Controls - 6.0L
P0700
Transmission Control Module (TCM) Requested MIL Illumination
ECM
DTC P0700 in Engine Controls - 6.0L
P0703
Brake Switch 2 Circuit
TCM
DTC P0703 in Cruise Control
P0711
Transmission Fluid Temperature (TFT) Sensor Performance
TCM
DTC P0711 in Automatic Transmission - 4L60-E/4L65-E
P0712
Transmission Fluid Temperature (TFT) Sensor Circuit Low Voltage
ECM
DTC P0712 in Manual Transmission - Tremec 6-Speed
TCM
DTC P0712 in Automatic Transmission - 4L60-E/4L65-E
P0713
Transmission Fluid Temperature (TFT) Sensor Circuit High Voltage
ECM
DTC P0713 in Manual Transmission - Tremec 6-Speed
TCM
DTC P0713 in Automatic Transmission - 4L60-E/4L65-E
P0719
Brake Switch Circuit Low Voltage
TCM
DTC P0719 in Lighting Systems
P0722
Output Speed Sensor Circuit Low Voltage
TCM
DTC P0722 in Automatic Transmission - 4L60-E/4L65-E
P0723
Output Speed Sensor Circuit Intermittent
TCM
DTC P0723 in Automatic Transmission - 4L60-E/4L65-E
P0724
Brake Switch Circuit High Voltage
TCM
DTC P0724 in Lighting Systems
P0741
Torque Converter Clutch (TCC) System - Stuck Off
TCM
DTC P0741 in Automatic Transmission - 4L60-E/4L65-E
P0742
Torque Converter Clutch (TCC) System - Stuck On
TCM
DTC P0742 in Automatic Transmission - 4L60-E/4L65-E
P0751
1-2 Shift Solenoid (SS) Valve Performance - No First or Fourth Gear
TCM
DTC P0751 in Automatic Transmission - 4L60-E/4L65-E
P0752
1-2 Shift Solenoid (SS) Valve Performance - No Second or Third Gear
TCM
DTC P0752 in Automatic Transmission - 4L60-E/4L65-E
P0756
2-3 Shift Solenoid (SS) Valve Performance - No First or Second Gear
TCM
DTC P0756 in Automatic Transmission - 4L60-E/4L65-E
P0757
2-3 Shift Solenoid (SS) Valve Performance - No Third or Fourth Gear
TCM
DTC P0757 in Automatic Transmission - 4L60-E/4L65-E
P0787
3-2 Shift Solenoid (SS) Control Circuit Low Voltage
TCM
DTC P0787 in Automatic Transmission - 4L60-E/4L65-E
P0788
3-2 Shift Solenoid (SS) Control Circuit High Voltage
TCM
DTC P0788 in Automatic Transmission - 4L60-E/4L65-E
P0801
Reverse Inhibit Solenoid Control Circuit
ECM
DTC P0801 in Manual Transmission - Tremec 6-Speed
P0803
Skip Shift Solenoid Control Circuit
ECM
DTC P0803 in Manual Transmission - Tremec 6-Speed
P0833
Clutch Pedal Switch 2 Circuit
ECM
DTC P0833 in Manual Transmission - Tremec 6-Speed
P0894
Transmission Component Slipping
TCM
DTC P0894 in Automatic Transmission - 4L60-E/4L65-E
P0961
Line Pressure Control (PC) Solenoid System Performance
TCM
DTC P0961 in Automatic Transmission - 4L60-E/4L65-E
P0973
1-2 Shift Solenoid (SS) Control Circuit Low Voltage
TCM
DTC P0973 in Automatic Transmission - 4L60-E/4L65-E
P0974
1-2 Shift Solenoid (SS) Control Circuit High Voltage
TCM
DTC P0974 in Automatic Transmission - 4L60-E/4L65-E
P0976
2-3 Shift Solenoid (SS) Control Circuit Low Voltage
TCM
DTC P0976 in Automatic Transmission - 4L60-E/4L65-E
P0977
2-3 Shift Solenoid (SS) Control Circuit High Voltage
TCM
DTC P0977 in Automatic Transmission - 4L60-E/4L65-E
P1101
Intake Air Flow System Performance
ECM
DTC P1101 in Engine Controls - 6.0L
P1133
HO2S Insufficient Switching Bank 1 Sensor 1
ECM
DTC P1133 or P1153 in Engine Controls - 6.0L
P1134
HO2S Transition Time Ratio Bank 1 Sensor 1
ECM
DTC P1134 or P1154 in Engine Controls - 6.0L
P1153
HO2S Insufficient Switching Bank 2 Sensor 1
ECM
P1154
HO2S Transition Time Ratio Bank 2 Sensor 1
ECM
P1258
Engine Coolant Overtemperature - Protection Mode Active
ECM
DTC P1258 in Engine Cooling
P1380
Misfire Detected - Rough Road Data Not Available
ECM
DTC P1380 in Engine Controls - 6.0L
P1381
Misfire Detected - No Communication With Brake Control Module
ECM
DTC P1381 in Engine Controls - 6.0L
P1482
Cooling Fan Speed Output Circuit
ECM
DTC P1482 in Engine Cooling
P1516
Throttle Actuator Control (TAC) Module Throttle Actuator Position Performance
ECM
DTC P1516 in Engine Controls - 6.0L
P1617
Engine Oil Level Switch Circuit
ECM
DTC P1617 in Instrument Panel, Gages, and Console
P1621
Control Module Long Term Memory Performance
ECM
P1621
Transmission Control Module (TCM) Long Term Memory Performance
TCM
P1630
Theft Deterrent Learn Mode Active
ECM
DTC P1630 in Theft Deterrent
P1631
Theft Deterrent Fuel Enable Signal Not Correct
ECM
DTC P1631 in Theft Deterrent
P1682
Ignition 1 Switch Circuit 2
ECM
DTC P1682 in Engine Controls - 6.0L
P1810
Transmission Fluid Pressure (TFP) Position Switch Circuit
TCM
DTC P1810 in Automatic Transmission - 4L60-E/4L65-E
P1815
Transmission Fluid Pressure (TFP) Valve Position Switch - Start in Wrong Range
TCM
DTC P1815 in Automatic Transmission - 4L60-E/4L65-E
P1816
Transmission Fluid Pressure (TFP) Valve Position Switch Indicates Park/Neutral (P/N) with Drive Ratio
TCM
DTC P1816 in Automatic Transmission - 4L60-E/4L65-E
P2066
Fuel Level Sensor 2 Performance
ECM
DTC P2066 or P2636 in Instrument Panel, Gages, and Console
P2067
Fuel Level Sensor 2 Circuit Low Voltage
ECM
DTC P2067 in Instrument Panel, Gages, and Console
P2068
Fuel Level Sensor 2 Circuit High Voltage
ECM
DTC P2068 in Instrument Panel, Gages, and Console
P2101
Control Module Throttle Actuator Position Performance
ECM
DTC P2101 in Engine Controls - 6.0L
P2119
Throttle Closed Position Performance
ECM
DTC P2119 in Engine Controls - 6.0L
P2120
Accelerator Pedal Position (APP) Sensor 1 Circuit
ECM
DTC P2120 in Engine Controls - 6.0L
P2122
Accelerator Pedal Position (APP) Sensor 1 Circuit Low Voltage
ECM
DTC P2122 in Engine Controls - 6.0L
P2123
Accelerator Pedal Position (APP) Sensor 1 Circuit High Voltage
ECM
DTC P2123 in Engine Controls - 6.0L
P2125
Accelerator Pedal Position (APP) Sensor 2 Circuit
ECM
DTC P2125 in Engine Controls - 6.0L
P2127
Accelerator Pedal Position (APP) Sensor 2 Circuit Low Voltage
ECM
DTC P2127 in Engine Controls - 6.0L
P2128
Accelerator Pedal Position (APP) Sensor 2 Circuit High Voltage
ECM
DTC P2128 in Engine Controls - 6.0L
P2135
Throttle Position (TP) Sensor 1-2 Correlation
ECM
DTC P2135 in Engine Controls - 6.0L
P2138
Accelerator Pedal Position (APP) Sensor 1-2 Correlation
ECM
DTC P2138 in Engine Controls - 6.0L
P2176
Minimum Throttle Position Not Learned
ECM
DTC P2176 in Engine Controls - 6.0L
P2610
Control Module Ignition Off Timer Performance
ECM
P2636
Fuel Transfer Pump Flow Insufficient
ECM
P2763
Torque Converter Clutch (TCC) Pressure Control (PC) Solenoid Control Circuit High Voltage
TCM
DTC P2763 in Automatic Transmission - 4L60-E/4L65-E
P2764
Torque Converter Clutch (TCC) Pressure Control (PC) Solenoid Control Circuit Low Voltage
TCM
DTC P2764 in Automatic Transmission - 4L60-E/4L65-E
P2769
Torque Converter Clutch (TCC) Enable Solenoid Control Circuit Low Voltage
TCM
DTC P2769 in Automatic Transmission - 4L60-E/4L65-E
P2770
Torque Converter Clutch (TCC) Enable Solenoid Control Circuit High Voltage
TCM
DTC P2770 in Automatic Transmission - 4L60-E/4L65-E
U0001
High Speed CAN Communication Bus
ECM
DTC U0001 in Computer/Integrating Systems
U0101
Lost Communications with Transmission Control Module (TCM)
ECM
DTC U0100-U0299 in Computer/Integrating Systems
U0121
Lost Communications with Electronic Brake Control Module (EBCM)
ECM
U0140
Lost Communication With Body Control Module (BCM)
ECM
U1000
Class 2 Data Link
BCM, DDM, DDS, DPM, DRR, FTC, HUD, IPC, PDM, Radio, RCDLR, SCLCM, SDM, VCIM
DTC U1000 and U1255 in Computer/Integrating Systems
U1017
Lost Communications with Engine Control Module (ECM)
DDM, DDS, DRR, FTC, HVAC, HUD, IPC, PDM, Radio, RCDLR, SDM, VCIM
DTC U1001-U1254 in Computer/Integrating Systems
U1024
DDS, DDM, DPM, FTC, IPC, HUD, PDM, Radio, RCDLR
U1040
IPC
U1064
Lost Communications with Body Control Module (BCM)
DDM, DDS, DPM, DRR, FTC, HVAC, HUD, IPC, PDM, Radio, RCDLR, SDM, VCIM
U1088
Lost Communication with Sensing and Diagnostic Module (SDM)
BCM, IPC
U1096
Lost Communication with Instrument Panel Cluster (IPC)
BCM, DDM, HUD, HVAC, PDM, Radio, SDM
U1098
Lost Communications with Head Up Display (HUD)
BCM, IPC
U1128
Lost Communications with Radio
DRR, IPC, HUD
U1137
Lost Communications with Digital Radio Receiver (DRR)
Radio
U1151
Lost Communications with Communication Interface Module (OnStar®)
IPC
U1153
Lost Communication with HVAC Control Module
BCM, DDM, IPC, HUD, PDM, Radio
U1160
Lost Communications with Driver Door Module (DDM)
IPC
U1161
Lost Communications with Passenger Door Module (PDM)
IPC
U1164
Lost Communications with Driver Door Switch (DDS)
DDM, DPM, DRR, IPC, PDM, Radio, RCDLR
U1166
Lost Communication with Driver Position Module (DPM)
IPC
U1177
Lost Communications with Folding Top Controller (FTC)
DDM, HVAC, IPC, PDM
U1193
Lost Communications with Remote Control Door Lock Receiver (RCDLR)
BCM, DDM, DDS, DPM, DRR, FTC, HVAC, HUD, IPC, PDM, Radio, SDM, VCIM
U1194
Lost Communications with Steering Column Lock Control Module (SCLCM)
BCM, IPC
U1255
Class 2 Data Link
HVAC
U1300
Class 2 Data Link Low
DDM, DDS, DRR, HVAC, IPC, PDM, Radio, SDM, VCIM
DTC U1300, U1301, or U1305 in Computer/Integrating Systems
U1301
Class 2 Data Link High
U1305
Class 2 Data Link Low or High
BCM, DPM, FTC, HUD, SCLCM
U1500
Inter-device Dedicated Bus 1
VCIM
DTC U1500 in Cellular Communication
U2100
Controller Area Network (CAN) Bus Communication
ESC, BCM, EBCM, TCM
DTC U2100 in Computer/Integrating Systems
U2105
Lost Communication with Engine Control Module (ECM)
BCM, EBCM, ESC, TCM
DTC U2105-U2199 in Computer/Integrating Systems
U2106
Lost Communication With Transmission Control Module (TCM)
BCM, EBCM
U2107
EBCM, ESC, TCM
U2108
Lost Communication With Electronic Brake Control Module (EBCM)
BCM, ESC, TCM
U2112
Lost Communications With Electronic Suspension Control Module (ESC)
EBCM
U2153
Navigation Electronic Control Unit (ECU) - VICS Communication Circuit
Navigation Radio
DTC U2153 in
DTC
DTC Descriptor
B0001
Navigation Radio
B0005
BCM, SCLCM
B0012
SDM
B0013
SDM
B0014
SDM
B0016
SDM
B0017
SDM
B0018
SDM
B0022
SDM
B0024
SDM
B0026
SDM
B0028
SDM
B0029
SDM
B0030
SDM
B0040
SDM
B0041
SDM
B0042
SDM
B0043
SDM
B0044
SDM
B0045
SDM
B0051
SDM
DTC B0051 in SIR
B0053
SDM
DTC B0053 in SIR
B0057
SDM
B0058
SDM
B0059
SDM
B0064
SDM
B0065
SDM
B0066
SDM
B0077
SDM
B0078
SDM
B0079
SDM
B0080
SDM
B0081
SDM
B0082
SDM
B0083
SDM
B0084
SDM
B0090
SDM
DTC B0090 in SIR
B0091
SDM
DTC B0091 in SIR
B0100
SDM
B0101
SDM
B0102
SDM
B0103
SDM
B0104
SDM
B0105
SDM
B0159
HVAC
B0164
HVAC
B0174
HVAC
B0179
HVAC
B0184
HVAC
B0189
HVAC
B0248
HVAC
B0249
HVAC
B0268
HVAC
B0269
HVAC
B0408
HVAC
B0409
HVAC
B0419
HVAC
B0423
HVAC
B0510
HVAC
B0515
HVAC
B0976
BCM
B0977
BCM
B0978
BCM
B1000
B1001
BCM
DRR, Radio,
SDM
DTC B1001 in SIR
B1004
B1007
EEPROM Write Error
B1009
B1011
DDM, PDM
DTC B1011 in Doors
FTC
DTC B1011 in Roof
B1013
HVAC
B1014
HVAC
B1259
Radio
B1271
Theft Locked
Radio
B1291
FTC
DTC B1291 in Roof
B1325
BCM
B1327
B1328
B1336
DPM/MSM
DTC B1336 in Seats
B1370
RCDLR
B1420
Device Voltage
DDM, PDM
DTC B1420 in Doors
FTC
DTC B1420 in Roof
DPM/MSM
DTC B1420 in Seats
B1440
RCDLR
B1451
BCM
B1474
DDM, PDM, RCDLR
B1480
BCM
B1580
DDM, PDM
B1590
DDM, PDM
B1600
DDM, PDM
B1605
DDM, PDM
B1697
DDSA
B1702
DDSA
B1707
DDSA
B1712
DDSA
B1735
DPM/MSM
B1740
DPM/MSM
B1745
DPM/MSM
B1750
DPM/MSM
B1755
DPM/MSM
B1760
DPM/MSM
B1815
DPM/MSM
B1820
DPM/MSM
B1825
DPM/MSM
B1826
DPM/MSM
B2355
DPM/MSM
B2356
DPM/MSM
B2365
DPM/MSM
B2366
DPM/MSM
B2375
DPM/MSM
B2376
DPM/MSM
B2455
VCIM
B2462
Navigation Radio
B2470
VCIM
B2476
VCIM
B2482
VCIM
B2483
VCIM
B2484
VCIM
B2510
SCLCM
B2515
SCLCM
B2517
DDM, PDM
B2518
DDM, PDM
B2527
BCM
DTC B2527 in Horns
B2528
BCM
DTC B2528 in Horns
B2530
BCM
B2540
BCM
B2567
BCM
B2573
BCM
B2580
BCM
B2625
BCM
B2710
RCDLR
B2757
DDM
B2762
DDM
B2853
DPM/MSM
B2858
DPM/MSM
B2860
DPM/MSM
B2873
DPM/MSM
B2878
DPM/MSM
B2897
SCLCM
B2907
BCM, SCLCM
B2910
SCLCM
B2981
DDM, PDM, RCDLR
B3089
BCM
B3119
RCDLR
B3120
RCDLR
B3121
RCDLR
B3122
RCDLR
B3142
DDSA
B3145
PDM
B3152
DDSA
B3155
PDM
B3170
PDM
B3175
PDM
B3205
DDM
DTC B3205 in Doors
B3280
PDM
B3377
DDSA
B3382
DDSA
B3387
DDSA
B3392
DDSA
B3467
DDSA
B3472
DDSA
B3542
DDM, PDM
DTC B3542 in Doors
B3602
FTC
DTC B3602 in Roof
B3618
BCM
B3619
HUD
B3620
HUD
B3621
HUD
B3634
HUD
B3659
HUD
B3666
FTC
DTC B3666 in Roof
B3667
FTC
DTC B3667 in Roof
B3670
FTC
DTC B3670 in Roof
B3715
BCM
B3744
HUD
B3794
BCM
B3810
BCM
B3848
DDM, PDM, RCDLR
B3849
DDM, PDM, RCDLR
B3948
BCM
B3949
BCM
B3950
BCM
B3951
BCM
B3971
FTC
DTC B3971 in Roof
C0035
EBCM
C0040
EBCM
C0045
EBCM
C0050
EBCM
C0110
Pump Motor Circuit
EBCM
C0136
EBCM
C0137
EBCM
C0161
EBCM
C0179
System Thermal High
EBCM
C0186
EBCM
C0196
Yaw Rate Circuit
EBCM
C0220
EBCM
C0221
EBCM
C0228
EBCM
C0229
EBCM
C0240
EBCM
C0242
EBCM
C0249
EBCM
C0250
EBCM
C0252
EBCM
C0253
Centering Error
EBCM
C0267
EBCM
C0277
BCM
C0278
BCM
C0281
EBCM
C0550
EBCM
ESC
C0551
EBCM
C0558
ESC
C0561
EBCM
C0565
EBCM
C0575
ESC
C0580
ESC
C0585
ESC
C0590
ESC
C0615
ESC
C0620
ESC
C0625
ESC
C0630
ESC
C0696
ESC
C0710
RCDLR
C0750
RCDLR
C0755
RCDLR
C0760
RCDLR
C0765
RCDLR
C0820
EBCM Case Voltage
EBCM
C0870
EBCM
BCM
C0895
Device Voltage
ESC
C0899
EBCM
C0900
EBCM
C1241
EBCM
P0016
ECM
P0030
ECM
P0036
ECM
P0050
ECM
P0056
ECM
P0068
ECM
P0101
ECM
P0102
ECM
P0103
ECM
P0106
ECM
P0107
ECM
P0108
ECM
P0112
ECM
P0113
ECM
P0116
ECM
P0117
ECM
P0118
ECM
P0120
ECM
P0121
ECM
P0122
ECM
P0123
ECM
P0128
ECM
P0131
ECM
P0132
ECM
P0133
ECM
P0134
ECM
P0135
ECM
P0136
ECM
P0137
ECM
P0138
ECM
P0140
ECM
P0141
ECM
P0151
ECM
P0152
ECM
P0153
ECM
P0154
ECM
P0155
ECM
P0156
ECM
P0157
ECM
P0158
ECM
P0160
ECM
P0161
ECM
P0171
ECM
P0172
ECM
P0174
ECM
P0175
ECM
P0201
ECM
P0202
ECM
P0203
ECM
P0204
ECM
P0205
ECM
P0206
ECM
P0207
ECM
P0208
ECM
P0218
TCM
P0220
ECM
P0222
ECM
P0223
ECM
P0230
ECM
P0300
ECM
P0315
ECM
P0325
ECM
P0326
ECM
P0327
ECM
P0332
ECM
P0335
ECM
P0336
ECM
P0340
ECM
P0341
ECM
P0351
ECM
P0352
ECM
P0353
ECM
P0354
ECM
P0355
ECM
P0356
ECM
P0357
ECM
P0358
ECM
P0420
ECM
P0430
ECM
P0442
ECM
P0443
ECM
P0446
ECM
P0449
ECM
P0451
ECM
P0452
ECM
P0453
ECM
P0454
ECM
P0455
ECM
P0461
ECM
P0462
ECM
P0463
ECM
P0464
ECM
P0496
ECM
P0502
ECM
P0503
ECM
P0506
Idle Speed Low
ECM
P0507
Idle Speed High
ECM
P0521
ECM
P0522
ECM
P0523
ECM
P0531
HVAC
P0532
HVAC
P0533
HVAC
P0562
System Voltage Low
ECM
TCM
P0563
System Voltage High
ECM
TCM
P0572
ECM
P0573
ECM
P0575
ECM
P0601
ECM
P0601
TCM
P0602
ECM
P0602
TCM
P0603
ECM
P0603
TCM
P0604
ECM
P0604
TCM
P0606
ECM
P0607
ECM
P0608
ECM
P060E
ECM
P060D
ECM
P0615
ECM
P0621
ECM
P0622
ECM
P0641
ECM
P0646
HVAC
P0647
HVAC
P0650
ECM
P0651
ECM
P0654
ECM
P0685
ECM
P0689
ECM
P0690
ECM
P0700
ECM
P0703
TCM
P0711
TCM
P0712
ECM
TCM
P0713
ECM
TCM
P0719
TCM
P0722
TCM
P0723
TCM
P0724
TCM
P0741
TCM
P0742
TCM
P0751
TCM
P0752
TCM
P0756
TCM
P0757
TCM
P0787
TCM
P0788
TCM
P0801
ECM
P0803
ECM
P0833
ECM
P0894
TCM
P0961
TCM
P0973
TCM
P0974
TCM
P0976
TCM
P0977
TCM
P1101
ECM
P1133
ECM
P1134
ECM
P1153
ECM
P1154
ECM
P1258
ECM
P1380
ECM
P1381
ECM
P1482
ECM
P1516
ECM
P1617
ECM
P1621
ECM
P1621
TCM
P1630
ECM
P1631
ECM
P1682
ECM
P1810
TCM
P1815
TCM
P1816
TCM
P2066
ECM
P2067
ECM
P2068
ECM
P2101
ECM
P2119
ECM
P2120
ECM
P2122
ECM
P2123
ECM
P2125
ECM
P2127
ECM
P2128
ECM
P2135
ECM
P2138
ECM
P2176
ECM
P2610
ECM
P2636
ECM
P2763
TCM
P2764
TCM
P2769
TCM
P2770
TCM
U0001
ECM
U0101
ECM
U0121
ECM
U0140
ECM
U1000
Class 2 Data Link
U1017
U1024
U1040
IPC
U1064
U1088
BCM, IPC
U1096
U1098
BCM, IPC
U1128
DRR, IPC, HUD
U1137
Radio
U1151
IPC
U1153
U1160
IPC
U1161
IPC
U1164
U1166
IPC
U1177
DDM, HVAC, IPC, PDM
U1193
U1194
BCM, IPC
U1255
Class 2 Data Link
HVAC
U1300
U1301
U1305
U1500
VCIM
U2100
ESC, BCM, EBCM, TCM
U2105
BCM, EBCM, ESC, TCM
U2106
BCM, EBCM
U2107
EBCM, ESC, TCM
U2108
BCM, ESC, TCM
U2112
EBCM
U2153
Navigation Radio
DTC U2153 in
- Marvin
Super danke dir werde den Thread. Später mal umbenenne. Geldrcode der c6. Kann da einer auch in deutsch schreiben ![biggrin [smilie=biggrin.gif]](./images/smilies/biggrin.gif)
5 Beiträge
