Wenn das Lenkradschloss noch funktioniert wird einfach der Eli eingebaut wenn der Sperrbolzen zurückgeschoben ist. Lenkradschloss kann sitzen bleiben, alles in allen ungefähr 30 Minuten Arbeit. Anleitung auf English
2005 corvette COLUMN LOCK ELIMINATOR for manual trans cars
install instructions
1. Remove the instrument panel trim
i. Lower the tilt steering column to lowest postion
ii. Pull outward on lower edge of trim panel
iii. Dissconnect eletrical connectors on dic buttons
2. Remove instrument cluster
i. Remove instrument cluster bolts (4)
ii. Move the instrument cluster out of the way
3. Find the black box located on pass. Side of the steering column support bracket (steering column lock module)
4 push the ignition button putting car in accessory mode UNLOCKING THE STEERING COLUMN LOCK
5. Remove the harness from column lock module with blk,orng,pupl,grn wires or later models computer ribbon is used instead of wires
6. Plug the cle into the column lock module
7. Reassemble
