C6 LS2 SLP Blackwing CAI
Beitragvon Blue » 27.02.16, 09:50
Cold Air Intake System, 2005-2007 Blackwing LS2
Wegen Falschlieferung zu verkaufen.
- Neu
- Verzollt und versteuert
- Waschbar mit Zustandsanzeige
- Einfacher Einbau
- Keine Modifikationen notwendig
- Leistungssteigernd
- VB 400.-
Bei Interesse bitte PN
Klaus
One the quickest and most inexpensive ways to increase the performance of your C6 is with our 2005-2007 Corvette Blackwing Air Intake Package by SLP. Each unit is a direct replacement package, simply remove the restrictive OE Air Intake housing and install our Blackwing Air Intake Package. You will immediately noticed increased engine efficiency and performance as SLP's C6 Corvette Blackwing Air Intake allows the engine to intake air more efficiently than any other system on the market. The Blackwing Air Filter element is made of 100% Synteq, a man-made fiber, that traps smaller contaminants than cotton or oiled-cotton media while increasing air flow. Additionally, you don't have to guess when the Blackwing Air Filter needs to be cleaned, just check the exclusive Air Flow Indicator, it will tell you when cleaning is needed. Each Corvette Blackwing Air Intake Package includes all hardware and instructions for a simple bolt on installation.
Fit All 2005-2007 Corvette with 6.0L LS2 Engine
Up to 10 Additional Horsepower and 11 ft / lbs of Torque at the Flyweel
90% Increase of Airflow Into the Engine
Washable & Reusable High Flow Air Filter Element
Includes High-Volume Air Bridge and Built In Flow Indicator
SLP Exclusive
www.fettevette.de
79er Export Corvette
08 C6 Convertible JSB
Blue
Fahrzeug: C6 CV, 2008, Jetstream Blue
